No first gear. - ThePullingPlace.com
Go Back   ThePullingPlace.com > Dodge Diesel & Truck Discussion > 5.9L Cummins (2003-2007)
5.9L Cummins (2003-2007) Discussion about the 3rd generations Cummins
Old 04-07-2009, 06:16 AM   #1
MoPower05
MoPower05's Avatar
Default No first gear.
After putting in the new motor in my silver 2005, 7-10 days the transmission started shifting funny. At first trans temp light sometimes flashes on and sometimes with the chime. The trans temp sometimes was cold still. It would act up between 3rd and 4th. The tow haul light also would ficker on and off during this, so I replaced the govner solenoid and transister in the pan. Great! problem solved. But ever since there has been no first gear. Transmission place said they bypassed the ECU and transmission works fine. Last night I put my other ECU back in and still no first gear. How do I solve this? Anyone ever seen this?
Thanks.
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
2005 dodge 4x4,2500 silver sport, cummins of course, motor new 3-9-09, gen2 header, ARP studs, DDP injectors, edge hot w/A2, 4" silverline, custom intake, gauges, turbo timer, r&p 4.11, short bed dually.(tow truck)
2005 dodge 4x4, white flat bed, cummins 3500 qc, drw (puller
Silly gassers, pulling is for smokers.
For the latest pull video goto:
GDP (Gota Dodge Puller)
MoPower05 is offline   Reply With Quote
Old 04-07-2009, 12:47 PM   #2
JIT
Never First
JIT's Avatar
Reflash that sum-bitch!
Team GDP
Fear the HoodStack
"Beating a Ford is like winning at the Special Olympics. Not really something worth bragging about!"
JIT is offline   Reply With Quote
Old 04-07-2009, 02:01 PM   #3
G D P
G D P's Avatar
is no first better than no overdrive?
Home Of The F.A.F. Product Line.
G D P is offline   Reply With Quote
Old 04-07-2009, 05:40 PM   #4
fordt
fordt's Avatar
Is there a check box when having the tranny rebuilt?
Would you rather have Overdrive ( X) or 1st gear( )?
-Wayne
2008 44' Eliminator
Powered By -
Shined By -
fordt is offline   Reply With Quote
Old 04-07-2009, 07:42 PM   #5
MoPower05
MoPower05's Avatar
Two ECU's both fresh flashes at $107.00 each.
Old 04-07-2009, 08:26 PM   #6
Ironhead107
Have you tried a voltage regulator? or governor pressure sensor?
Ironhead107 is offline   Reply With Quote
Old 04-07-2009, 08:56 PM   #7
MoPower05
MoPower05's Avatar
no 1st best on silver truck so I can drive it.
no 4th best on white flat bed so I can still pull.
and that is exactly what I've had this year.
Old 04-08-2009, 07:11 AM   #8
fordt
fordt's Avatar
Who is building these trannies?
-Wayne
2008 44' Eliminator
Powered By -
Shined By -
Old 04-08-2009, 07:46 AM   #9
MoPower05
MoPower05's Avatar
Trannys fine thats the problem. Cant fix what aint broke. It is an electical problem since the new motor. This transmission hasnt been rebuilt still stock.
Old 04-08-2009, 07:47 AM   #10
MoPower05
MoPower05's Avatar
Yes both new.
