made my hitch finally - Page 3 - ThePullingPlace.com
Go Back   ThePullingPlace.com > Sled Pulling Chatter > Truck Pulling Hitches
Truck Pulling Hitches Show your hitch off, ask questions.
Old 01-19-2010, 06:20 PM   #21
Chris611
Originally Posted by dieselbeef View Post
on off the trigger to get that roll of pennys look isnt very good for penetration. i can tell that wasnt one long consistant bead. it might look good but im sure its full of viods.
not meaning to be bustin on anyone cuz im sur itll work but....
To add to what he said, one of the weakest parts of a weld are the start and the end of the weld. The start becasue there is the transisition from the base material to the weld material and that area is weak. Same thing at the end of the weld. The start and stop of a weld are good places for cracks to start. Best thing is to get the weld started and don't stop. This is hard to do without proper fixturing and or rotators. This is just scratching the surface. But that being said, the amount of use that a pulling hitch sees is basically nothing. The chance of a fatigue crack on a pulling his is non existant. You would have to hit tens of thousands of cycles to worry about that. So basically the hitch just has to hold the load once. You should be fine.
Later
Chris611 is offline   Reply With Quote
Old 01-20-2010, 07:46 AM   #22
dieselbeef
dieselbeef's Avatar
welds break from stress crack everyday...in adequate penetration will fail the first time or the last time..do u know hich one? maybe right at the end of the track wide open 40 ft from the finish in wauchula when it snaps....
02 silver quad, iis silver 62,iis hrvp,100hp inj, 6'' cat stack, drag comp, smarty, bd intake, 35's on beadlocks, a werkin truck...
dieselbeef is offline   Reply With Quote
Old 01-20-2010, 08:12 PM   #23
JIT
Never First
JIT's Avatar
U got my hitch done yet? pullin saturday!
Team GDP
Fear the HoodStack
"Beating a Ford is like winning at the Special Olympics. Not really something worth bragging about!"
JIT is offline   Reply With Quote
Old 01-21-2010, 09:23 AM   #24
dieselbeef
dieselbeef's Avatar
umm...parts please sir....let me direct yer call
Old 01-21-2010, 09:57 AM   #25
JIT
Never First
JIT's Avatar
Well Im not pulling this weekend so you now have more time to get it done!
Team GDP
Fear the HoodStack
Old 01-21-2010, 10:55 AM   #26
dieselbeef
dieselbeef's Avatar
BRING IT AFTER MY TRANS SHOWS UP AND GET MY WIFE OFF THE HOOK FOR HELPING ME..
WE CAN WELD IT UP ''AFTER'' THE TRANS IS IN!!
AT LEAST THE HEAVY PARTS..TRANS AND TRANSFER CASE...
Old 01-21-2010, 03:53 PM   #27
JIT
Never First
JIT's Avatar
I lay on the floor and put that **** in by myself weenie! Jr just laughs when I sit under the truck and put the transfer case in. Of coarse your truck is lower than mine. And im probably a little stronger than you.
Team GDP
Fear the HoodStack
Old 01-22-2010, 01:44 PM   #28
dieselbeef
dieselbeef's Avatar
cuz yer shorter dont mean yer stronger..so what if i cant stand under my truk like you...dont worry little one..ill git the trans in w/o ya ..i got it out by liftin it ill git it back in the same way..cuz i got no choice
Old 02-17-2010, 10:50 PM   #29
wickedweasel
GDP
wickedweasel's Avatar
it looks great man! nice welds!
2004 Ford F-250 6.0L
wickedweasel is offline   Reply With Quote
Old 02-22-2010, 11:03 AM   #30
fordt
fordt's Avatar
Don't worry I had guys hating on my welds too. The hitch channel bent, never even cracked the welds.
-Wayne
2008 44' Eliminator
Powered By -
Shined By -
fordt is offline   Reply With Quote
