78 f250 puller - ThePullingPlace.com
Go Back   ThePullingPlace.com > Sled Pulling Chatter > Builds/Projects
Builds/Projects Post up what you are working on
Old 08-27-2010, 09:27 PM   #1
MPac
Superman
Default 78 f250 puller
I'm working on my project that is a daily driver. I will be pulling cheater stock with the COPTC for the 2011 season. Specs on the truck 460 big block stock C6 with a 203 case. Yes it is full time 4 wheel drive. One question I have about pulling is. When I pull should I pull in 4 low or 4 low lock?
Now for you those of you not familar you with the NP 203 case normal cases that are part time when you go in a 4 wheel drive gear it distributes equal power to the front and back. with the full time case 4 low or 4 hi have a differental in it. Meaning it acts kinda like a posi. When its in lock its the same as a part time case. Which should I pull in? Low or Low Lock. Thanks in advance for your help.
Get in
Sit down
Buckle up
Shut up and
HOLD ON!
1978 Ford f250 Ranger
460 big Block
C6 with a 203 full time 4wd baby!
Dana 60's
33's
MPac is offline   Reply With Quote
