Liberty Truck Rules - ThePullingPlace.com
ThePullingPlace.com
Go Back   ThePullingPlace.com > Georgia Pulling Scene > Georgia Pulling
Forgot Password?
ThePullingPlace.com is the premier Truck/Tractor Sled Pulling Forum on the internet. Registered Users do not see the above ads.
Reply
Thread Tools Display Modes
Old 05-24-2008, 11:33 PM   #1
TNRGreene
Administrator
TNRGreene's Avatar
Default Liberty Truck Rules
TRUCK PULL RULES 2008
Street Class Trucks
1) Driver must be 18 or older with a valid driver’s license. Drivers 16 & 17 may compete with their parent’s approval
2) No alcoholic beverages of any kind are permitted. Alcohol consumption or unsportsmanlike behavior will be grounds for disqualification
The classes are as follows and will pull in the order listed:
Two wheel drive with a maximum weight of 5500lb
4X4‘s with a maximum weight of 5500
Two wheel drive with a maximum weight of 6500 lbs
4X4‘s with a maximum weight of 6500 lbs
Street Class with a maximum weight of 6500 lbs
4X4‘s with a maximum weight of 7500 lb
Street Class with a maximum weight of 7500 lbs
Open Class with a maximum weight of 8500 lbs
Street Class with a maximum weight of 8500 lbs
Any truck can hook only once per class.
3) Trucks must be Street Legal. This means have must have Tag, Insurance, and D.O.T approved tires(no cut or altered tires)!
4) All trucks must have a hitch height of 30” maximum height to the top of the hitch.
All trucks must pull from a clevis or D ring with 3’’ ID.
5 No shifting allowed on Manuals.
6) A puller may have a second try if he/she stops within 75 feet of the start line. However, in a pull-off the puller has only one try.
7) No passengers allowed in the truck while it is pulling
8) Loss of equipment under the green will stop the pull
9) There will be an automatic disqualification in all classes if the pulling truck touches the sidelines.
10) All trucks when entering or leaving the property are not to exceed 5 mph and when not pulling must remain in the pit area
11) All registered pull trucks must have their number cards visible at all times in the windshield.
12) Pullers may have sled spotted on starting line where desired if he/she notifies sled operator in sufficient time when sled is returning to the starting line from the previous pull
13) All decisions concerning truck classification and/or eligibility will be made by the Track Officials.
14) Rules are subject to revision at any time by Track Officials.
15) At all times the trucks, drivers, and the pulls will be governed by Track Officials and Flagmen.
16) Entry fee will not be refunded if disqualified.
17) Lack of adherence to these rules will be grounds for disqualification.
18) Track Officials decisions are final.
Modified Truck Rules
1) All trucks must have factory-like hood, doors, seats, and bed - either pick up bed or flat bed.
2) All trucks must have a hitch height of 30” maximum height to the top of the hitch.
3) All trucks must pull from a clevis or D ring with 3’’ ID.
4) All trucks must have a kill switch on the rear of truck to stop engines in case of emergency.
5) No Nitrous or alcohol fuel.
6) All trucks must have working brakes with factory brake pedal.
7) Trucks will carry no fuel or batteries inside the cab.
8) Automatic transmissions need blanket.
9) Manual transmissions must have steel bell housing and fly wheel.
10) U joints on drive shafts must be shielded.
11) Trucks manufactured for pulling must have drive shaft loops.
12) Lack of adherence to these specifications will be grounds for disqualification.
13) Rules are subject to revision at any time by Track Officials.
14) All decisions concerning truck classification and/or eligibility will be made by the Track Officials.
15) Track Officials’ decisions are final.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
__________________
Todd
04.5 K2500 GMC Black
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Thanks to TJ, Steve, MA, Trippin & McRat Racing
Greene's Performance Diesel
Building winners since 2004
Home of:
~B & B Pulling Team
~2008 SFTP Street Diesel Champion- BLACKBALLED
~2008 SFTP Outlaw Diesel champion- FREIGHTTRAIN
~2009 FATC Street Diesel Champion- CODE RED
~2009 FATC Outlaw Diesel Champion BLACKBALLED
United We Smoke
Run your truck, not your mouth
TNRGreene is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
