Mounting of.... - ThePullingPlace.com
Go Back   ThePullingPlace.com > Sled Pulling Chatter > Traction Bars
Old 02-26-2009, 10:33 AM   #1
TNRGreene
TNRGreene's Avatar
Default Mounting of....
Traction bars. Everybody seems to mount them on the bottom of the axle. Is that out of laziness or functionality? What is the theory behind it? Why shouldn't they be mounted on top of the axle?
Discuss
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
Todd
04.5 K2500 GMC Black
Thanks to TJ, Steve, MA, Trippin & McRat Racing
Greene's Performance Diesel
Building winners since 2004
Home of:
~B & B Pulling Team
~2008 SFTP Street Diesel Champion- BLACKBALLED
~2008 SFTP Outlaw Diesel champion- FREIGHTTRAIN
~2009 FATC Street Diesel Champion- CODE RED
~2009 FATC Outlaw Diesel Champion BLACKBALLED
United We Smoke
Run your truck, not your mouth
TNRGreene is offline   Reply With Quote
Old 02-26-2009, 10:45 AM   #2
dieselbeef
dieselbeef's Avatar
the roatating action of the rear pushes upward on the truk pushin the rear down...if theyre made right..theoretically...i think...maybe...
02 silver quad, iis silver 62,iis hrvp,100hp inj, 6'' cat stack, drag comp, smarty, bd intake, 35's on beadlocks, a werkin truck...
dieselbeef is offline   Reply With Quote
Old 02-26-2009, 10:50 AM   #3
TNRGreene
TNRGreene's Avatar
correct but if you were to mount them on top & angle the frame mounting points lower then the axle mounting point, wouldn't it push(leverage) down on the front end more?
Todd
Home of:
~B & B Pulling Team
United We Smoke
Old 02-26-2009, 11:15 AM   #4
dieselbeef
dieselbeef's Avatar
they would hafta be pretty low and the front wheels are so far away that the leverage wouldnt work out...and then theyd be liftin on the rear axle as it tried to roll
Old 02-26-2009, 11:23 AM   #5
TNRGreene
TNRGreene's Avatar
lifting the rear doesn't matter much when the sled is on
Todd
Home of:
~B & B Pulling Team
United We Smoke
Old 02-26-2009, 11:38 AM   #6
dieselbeef
dieselbeef's Avatar
seperation would be yer issues at that point i think
Old 02-26-2009, 11:41 AM   #7
SSpeeDEMONSS
it would not work properly. you wouldnt want to try to pull the front down like that.
but hey, what do i know, maybe it would work. go try it.
Garrett
2003 F-250 6.0 XLT 4WD auto CCSB- SCT with DJ's Looney tune, airdog FP-150 with a custom fuel system by me, 4" straight pipe to 6" black cat stack, lots of other little things and train horns.
1994 2500 12v 5spd 4wd RCLB- a header and some timing with some springs, needs more air, fuel, and a clutch 382hp/1000tq
Elite Diesels
SSpeeDEMONSS is offline   Reply With Quote
Old 02-26-2009, 11:45 AM   #8
TNRGreene
TNRGreene's Avatar
Why not if I can get force down on the front end without weights? Not argueing either way just have not seen proof it would not work. That's why I put discuss
Todd
Home of:
~B & B Pulling Team
United We Smoke
Old 02-26-2009, 11:45 AM   #9
JIT
Never First
JIT's Avatar
The rear end rotates upward under torque not down. For instance, when you see a ford break the rear axle the pinion goes up not down.
Team GDP
Fear the HoodStack
"Beating a Ford is like winning at the Special Olympics. Not really something worth bragging about!"
JIT is offline   Reply With Quote
Old 02-26-2009, 11:48 AM   #10
TNRGreene
TNRGreene's Avatar
yes I know that. That is the discussion. Why would it not "force" down if mounted on top & low enough near the front of thr truck
Todd
Home of:
~B & B Pulling Team
United We Smoke
