Buck Marine Diesel - ThePullingPlace.com
Go Back   ThePullingPlace.com > General Site Information > Introductions
Introductions New to our forums? Take a minute to introduce yourself, include some pics and info on your truck, and get to know some of our members here!
Old 09-22-2008, 08:57 AM   #1
timbillyosu
Default Buck Marine Diesel
Just wanted to get the word out on a new Diesel engine. The engine is called a Buck Marine Diesel.
I work at Buck Marine Diesel. We are currently developing a prototype diesel engine specifically designed for inboard marine use, with over-the-road applications being considered for future versions. We're still working on things right now. We're getting VERY close to getting the first prototype fully up and running. We had it running yesterday for about an hour at around 2000 rpm without any problems. We need to do a little more work to get our dyno fully-functional but things are going good.
We are currently working on a 6-cylinder model with 3- and 4-cylinder models to follow. The engines have a unique two injector per cylinder design that will increase the fuel mapping potential exponentially and result in lower emissions capability. The family of engines will range from 150 to 700 HP and have been designed from the bottom up with a totally different approach. These engines are capable of exceptional cooling, allowing for substantial improvements in power output while increasing longevity.
The cooling path for this engine is a fraction of most engines. In the classic designs, coolant flows into the front of the engine, all the way back to the rear cylinder, then back out the front. This means that the rear cylinder is always receiving water that has already been heated by the previous cylinders.
In the Buck Marine system, the coolant flows individually into and out of each cylinder. This means that the all of the cylinders will be operating at the same temperature at all times. Using individual and shorter cooling paths, will also help eliminate hot spots and temperature stacking.
The engine also has a dual cooling system that uses both an internal coolant as well as circulating raw water from whatever body of water the boat is in. This cooling system will keep the engine running cool, allowing us to generate more power. If a problem should arise, the engine is also very serviceable.
The modular cylinder design allows for easy maintenance. With our design, you can change an individual cylinder, head, piston, and connecting rod without having to remove the crank case. We are estimating that the entire upper half of the engine (cylinders, heads, pistons, and connecting rods ) could be entirely replaced in about 2 hours time. Each of the aforementioned parts is also interchangeable with each of the other cylinders. In addition, nearly every seal is made with an o-ring of some form, meaning that the gasket set for the entire engine can fit in a gallon-sized plastic bag. These two factors will significantly reduce part inventory. A video of the connecting rod replacement procedure is available on the website.
Since we didn't have the dyno working properly yesterday, we're not positive on the actual power numbers. However, while running under a moderate load at about 2000 rpm, the exhaust temperatures were around 1000 degrees F. We ran under those conditions for about 15 minutes. The hottest that the coolant pump got was about 120 degrees F. None of the 6 heads were over 140 degrees and all of them were within about 5 degrees of one another. You could lay your hands on top of the valve covers.
Check out our website for further pictures and videos.
Feel free to ask any questions that you have.
http://www.buckdiesel.com
timbillyosu is offline   Reply With Quote
Old 09-22-2008, 12:19 PM   #2
TNRGreene
TNRGreene's Avatar
Sounds good
Welcome & keep us posted
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
Todd
04.5 K2500 GMC Black
Thanks to TJ, Steve, MA, Trippin & McRat Racing
Greene's Performance Diesel
Building winners since 2004
Home of:
~B & B Pulling Team
~2008 SFTP Street Diesel Champion- BLACKBALLED
~2008 SFTP Outlaw Diesel champion- FREIGHTTRAIN
~2009 FATC Street Diesel Champion- CODE RED
~2009 FATC Outlaw Diesel Champion BLACKBALLED
United We Smoke
Run your truck, not your mouth
TNRGreene is offline   Reply With Quote
Old 12-15-2008, 11:45 AM   #3
timbillyosu
sorry it has taken me so long to get back on here... we have been running the engine a bit and finding some problems that we are fixing. Hopefully within the next few weeks, we will have it back up and running and I will be able to give out some real power numbers.
Old 12-15-2008, 04:01 PM   #4
1JP
1JP's Avatar
Send a message via Yahoo to 1JP
Sounds good
We're all dealt unfavorable hands in life, it's all in how we play them out. "Folding" or "All In" is the difference between giving up or grabbing "Life by the Horns"!
05' Dodge 3500 Q-Cab 4x4 SLT SRW 48RE
1JP is offline   Reply With Quote
Old 12-15-2008, 11:39 PM   #5
Pit Crew
sweeeeeet new motors are cool
Greene Performance Diesel
Building winners since 2005
Home of:
~B & B Pulling Team
~2008 SWTP Street Diesel Champion
~2008 Outlaw Diesel champion
United We Smoke
Man Law-77. A man should be able to determine a diesel engine by sound alone.
Pit Crew is offline   Reply With Quote
Old 12-15-2008, 11:39 PM   #6
heminut
I read the article in diesel power mag lokks to me like its gonna be one heck of engine.
heminut is offline   Reply With Quote
Old 12-16-2008, 08:59 AM   #7
timbillyosu
it is one heck of an engine... one of the problems that we had was running too soft a camshaft. So we took the cam out to get it heat-treated. From the ready-to-run condition to having the cam out was, I'm not joking, we timed it, 1 (ONE) hour!
If you have any questions, please feel free to ask.
Old 12-23-2008, 11:36 AM   #8
timbillyosu
We have some preliminary power numbers.
So far, we have only gotten about 160 Hp at 9 gal/hr fuel burn. My boss's boat has 2 Cat diesels, when he is burning 35 gal/hr, he gets about 565 Hp. So let's assume it's a linear trend, at 36 gal/hr (4x our current fuel burn), we will be getting about 640 Hp! We are working to adjust our BSFC. These numbers were made with a BSFC around 0.45. We are still extremely happy with these numbers and as soon as we get more, I will be sure to let everyone know.
Old 01-20-2009, 01:20 PM   #9
2wpuller
2wpuller's Avatar
Very interresting please keep us informed of your progress.
Dale
1975 f250 6.0Perkins,twins,06 allison 6sp,HM.airride,4"ex,Airtilt.front clip.
72 chevy C10 5.9 cummins
2007 Dodge 2 WD pulling truck
Sponsors
GoerendTransmission
Haisley Machine
MCS MidwestPerformanceDiesel
ShowMePerformance
[/FONT]
2wpuller is offline   Reply With Quote
Old 07-08-2009, 02:22 PM   #10
timbillyosu
Hey all, sorry it has been a little while since I've posted. I've got a new clip of our engine. Check it out:
In this video, we take a running engine, shut it down and tear down a single cylinder to the bare crankshaft, rebuild it, and start the engine back up. All in less than 8 minutes!
Don't believe me? Watch it :-)
Let me know if you have any questions.
The Following User Says Thank You to timbillyosu for this Pulling Place addition.
fordt (07-09-2009)
