Mounting of.... - Page 3 - ThePullingPlace.com
Go Back   ThePullingPlace.com > Sled Pulling Chatter > Traction Bars
Old 02-26-2009, 08:56 PM   #21
6.0superduty
6.0superduty's Avatar
Originally Posted by JIT View Post
My Yugo had that set-up and with 145-25R13 Sumitomo Radials I never had a problem with traction.
Thats because any car with 45hp wont have a traction issue
07 LBZ
waiting to be modded
CODE RED (Sold)
04 6.0 CC SRW
some pullin goodies
2009 FATC Street Diesel Champion
Troyers Diesel Performance
Specializing In Superdutys
B & B Pulling Team
Hookin Ain't Easy!
6.0superduty is offline   Reply With Quote
Old 02-27-2009, 03:44 PM   #22
SSpeeDEMONSS
you can set a 4 link up to have a lot of lift on the rear end. you can also have it set up to have no lift.
as you said, its all in the set up.
Garrett
2003 F-250 6.0 XLT 4WD auto CCSB- SCT with DJ's Looney tune, airdog FP-150 with a custom fuel system by me, 4" straight pipe to 6" black cat stack, lots of other little things and train horns.
1994 2500 12v 5spd 4wd RCLB- a header and some timing with some springs, needs more air, fuel, and a clutch 382hp/1000tq
Elite Diesels
SSpeeDEMONSS is offline   Reply With Quote
Old 02-28-2009, 07:28 AM   #23
MoPower05
MoPower05's Avatar
What angle should these bars be ? (same as drive shaft, frame,does it matter)
What length is best?
Can they be too long, too short, too heavy?
Or does the angle determine the length ?
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
2005 dodge 4x4,2500 silver sport, cummins of course, motor new 3-9-09, gen2 header, ARP studs, DDP injectors, edge hot w/A2, 4" silverline, custom intake, gauges, turbo timer, r&p 4.11, short bed dually.(tow truck)
2005 dodge 4x4, white flat bed, cummins 3500 qc, drw (puller
Silly gassers, pulling is for smokers.
For the latest pull video goto:
GDP (Gota Dodge Puller)
MoPower05 is offline   Reply With Quote
Old 02-28-2009, 07:36 AM   #24
cuminstrkmydmax
The longer the better- on my CCLB Duramax they will be 7' 1'' eye to eye, putting them almost parallel to the ground when they are mounted! The shorter you go, the more binding issues you have- giving alot rougher ride. I dont see how they could be too heavy though. GOOD LUCK- Steven
cuminstrkmydmax is offline   Reply With Quote
Old 02-28-2009, 03:56 PM   #25
SSpeeDEMONSS
my CCSB are 7'1".
Garrett
Elite Diesels
Old 02-28-2009, 08:07 PM   #26
6.0superduty
thats what she said
07 LBZ
CODE RED (Sold)
04 6.0 CC SRW
some pullin goodies
B & B Pulling Team
Hookin Ain't Easy!
Old 03-01-2009, 07:18 AM   #27
dieselbeef
dieselbeef's Avatar
Originally Posted by 6.0superduty View Post
thats what she said
only til she seen it
02 silver quad, iis silver 62,iis hrvp,100hp inj, 6'' cat stack, drag comp, smarty, bd intake, 35's on beadlocks, a werkin truck...
dieselbeef is offline   Reply With Quote
Old 03-01-2009, 12:08 PM   #28
6.0superduty
07 LBZ
CODE RED (Sold)
04 6.0 CC SRW
some pullin goodies
B & B Pulling Team
Hookin Ain't Easy!
Old 03-25-2009, 10:51 AM   #29
getblown5.9
getblown5.9's Avatar
Send a message via AIM to getblown5.9
with leaf springs, if you mount the bar on top of the axle, the bottom of the axle will want to roll forward still.
here is the thing tho, tubing when under compression forces (bottom mounted) will want to deflect. when in tension (top mounted) its not going to deflect. to over come this problem you go with a heavy enough tube when bottom mounted to prevent the deflection, or go with a triangulated and shackle mounted "ladder" bar set-up.
i had the problem of deflection last year, my bars were made of a smaller thin wall tubing and i have pictures and video showing it bending into a slight arc under full force. i am now building a set of much heavier and longer bars that will not deflect.
2002 Dodge 2500 6spd with a Hybrid Cummins Engine
Run your truck, not your mouth.
getblown5.9 is offline   Reply With Quote
Old 03-25-2009, 12:49 PM   #30
dieselbeef
dieselbeef's Avatar
i saw that at the pulls this weekend..cept they didnt bend backstrait...looked not so good
