What Level - ThePullingPlace.com
ThePullingPlace.com
Go Back   ThePullingPlace.com > GM Diesel & Truck Discussion > Duramax 2001-2004 (LB7)
Forgot Password?
Duramax 2001-2004 (LB7) Discussion related to the 1st Gen LB7 Duramax
ThePullingPlace.com is the premier Truck/Tractor Sled Pulling Forum on the internet. Registered Users do not see the above ads.
Reply
Thread Tools Display Modes
Old 05-14-2008, 09:55 AM   #1
1BADLB7
Default What Level
HI THERE, on PPE HOT + 2 do you think i will be able to run it at the highest level, on my stock trans at the next pull.Will i need fuel system up grades? and if so what type should i be looking at.I have a few idea's of my own but i am new to diesel power.
1BADLB7 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-14-2008, 01:15 PM   #2
2wd_sled_puller
<<< MY day job
2wd_sled_puller's Avatar
Default
Run it on set to kill tune and add a lift pump. Pull 4 low 2nd or 3rd gear what ever u fill coffy with. give her hell
__________________
97 f350 7.3
Valair clucth Air dog, soon to be sct tuned
97 chevy 2500
5 tons running gear, 54 inch tires, and a slighty tuned motor
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
2wd_sled_puller is offline   Reply With Quote
Old 05-14-2008, 07:22 PM   #3
1BADLB7
Default
Sound's good to me. Thank's
Old 07-06-2008, 03:47 PM   #4
TNRGreene
Administrator
TNRGreene's Avatar
Default
even adding a lift pump you may still drain the rails. May need a different pickup in the tank. You will just have to see how it does. I could not run H+2 & keep fuel up top
H +2 will kill a stock trans shifting from 4th to 5th or 5th down to 4th under WOT
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
__________________
Todd
04.5 K2500 GMC Black
Thanks to TJ, Steve, MA, Trippin & McRat Racing
Greene's Performance Diesel
Building winners since 2004
Home of:
~B & B Pulling Team
~2008 SFTP Street Diesel Champion- BLACKBALLED
~2008 SFTP Outlaw Diesel champion- FREIGHTTRAIN
~2009 FATC Street Diesel Champion- CODE RED
~2009 FATC Outlaw Diesel Champion BLACKBALLED
United We Smoke
Run your truck, not your mouth
TNRGreene is offline   Reply With Quote
Old 07-10-2008, 10:59 AM   #5
SmokeShow
Default
you ever pull??? how'd you do???
SmokeShow is offline   Reply With Quote
Old 08-09-2008, 02:26 PM   #6
1BADLB7
Default still working on truck
I'm still working on things, i'm not in a hurry i will probley make it to the drag strip before i make it to a pull i'll let ya know how it go's.
Old 08-09-2008, 02:26 PM   #7
1BADLB7
Default
Just cant seem to find the time
Old 08-10-2008, 01:42 AM   #8
2wd_sled_puller
<<< MY day job
Default
Quote:
Pulling will be easyier on the tranny then racing ( IN YOUR CASE) Yes Todd is right u may need to make modifications to the fuel tank for it to hold pressure up top. Add lift pump put truck in first on the colunm go till about 2200 rpm punch it and see if it blows smoke consitedent
__________________
97 f350 7.3
97 chevy 2500
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2024, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
