5.9L Cummins 12 Valve (1994-1998.5) 2nd gen 12 valve trucks 94-98 The Dirty Dozen...mechanically controlled injection |
Thread Tools | Display Modes |
06-15-2009, 10:51 PM | #11 |
good you found the problem and it wasnt expensive!
07 LBZ waiting to be modded To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. CODE RED (Sold) 04 6.0 CC SRW some pullin goodies To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 2009 FATC Street Diesel Champion Troyers Diesel Performance Specializing In Superdutys B & B Pulling Team Hookin Ain't Easy! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Sponsored Links | |||
06-15-2009, 10:56 PM | #12 |
glad you found it
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
Todd 04.5 K2500 GMC Black To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Thanks to TJ, Steve, MA, Trippin & McRat Racing To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Greene's Performance Diesel Building winners since 2004 Home of: ~B & B Pulling Team ~2008 SFTP Street Diesel Champion- BLACKBALLED ~2008 SFTP Outlaw Diesel champion- FREIGHTTRAIN ~2009 FATC Street Diesel Champion- CODE RED ~2009 FATC Outlaw Diesel Champion BLACKBALLED United We Smoke Run your truck, not your mouth |
07-16-2009, 10:34 PM | #13 |
When it rains it pours! Anybody have any idea why the o-ring on top of the fuel filter would keep popping out after about 30 minutes of driving? I think it might have something to do with the return line
07-16-2009, 11:03 PM | #14 | |
07-17-2009, 07:50 AM | #15 |
Kind of sounds like your building a little too much pressure in there for some reason.
07-18-2009, 03:13 AM | #16 |
Tire Groover
if you get a new filter, does it come with an o-ring? the one for my fuhord does, maybe try that. also like kyle said maybe too much pressure also. Do you have an adjustable lift pump? what years your truck? VP44?
If the oring is shot and just sloppy loose like a 14th street.....ummmm worker.....on friday night, maybe thats why its popping out. I was told (i dont have one i could be wrong) that a VP44 truck doesnt like too much pressure, so if you have an adjustable pump turned way up, try backing it off some. |
07-18-2009, 03:15 AM | #17 |
Tire Groover
DUH i just realized its in the 12 valve section, so the pump thing goes out the window, but it still could be building too much pressure for what the oring can handle, if the o-ring or the assembly that its in is worn out. Def try calling Jr, and he should be able to help ya out!
07-18-2009, 08:38 AM | #18 |
The stud that the filter screws on somehow came loose and was vibrating down. All it took was a allen wrench! Thanks for the help guys
07-18-2009, 10:56 AM | #19 |
No problem. The easy fixes are always the best!
Sponsored Links | |
