Broke - ThePullingPlace.com
Go Back   ThePullingPlace.com > Dodge Diesel & Truck Discussion > 5.9L Cummins 12 Valve (1994-1998.5)
5.9L Cummins 12 Valve (1994-1998.5) 2nd gen 12 valve trucks 94-98 The Dirty Dozen...mechanically controlled injection
Old 06-08-2009, 02:10 PM   #1
Ironhead107
Unhappy Broke
My truck was running fine when I shut it off. When I tried to crank it back up it just turned over. Changed the fuel filter which had some trash in it and still nothing. Gas ragged it and it would just run off that and die. I pulled the banjo fitting going into the injection pump and there was what looked to be some dirt. I also pulled the fuel shutoff bracket off thinking that it might be the problem.After doing that it fired right up and ran fine. Test drove it for about 15 minutes and thought everything was fine. When I tried to start it about an hour later the same thing. I'm getting fuel to the inj pump but nothing out of it. Any suggestions?
Ironhead107 is offline   Reply With Quote
Old 06-08-2009, 05:11 PM   #2
6.0superduty
6.0superduty's Avatar
maybe something is wrong when it gets hot? I have no idea when it comes to a Cummins, just thinking out loud...
07 LBZ
waiting to be modded
CODE RED (Sold)
04 6.0 CC SRW
some pullin goodies
2009 FATC Street Diesel Champion
Troyers Diesel Performance
Specializing In Superdutys
B & B Pulling Team
Hookin Ain't Easy!
6.0superduty is offline   Reply With Quote
Old 06-08-2009, 05:28 PM   #3
Ironhead107
Could be. Thanks and keep them coming
Old 06-08-2009, 06:34 PM   #4
6.0superduty
do you have good pressure going into the injection pump? Assuming you have a lift pump feeding the injection pump?
07 LBZ
CODE RED (Sold)
04 6.0 CC SRW
some pullin goodies
B & B Pulling Team
Hookin Ain't Easy!
Old 06-08-2009, 09:45 PM   #5
Ironhead107
The pressure is good coming from the lift pump to the injection pump
Old 06-08-2009, 10:27 PM   #6
6.0superduty
loosen a couple of the lines going from the injection pump to the injectors and crank it over to see if fuel is getting to the injectors.
07 LBZ
CODE RED (Sold)
04 6.0 CC SRW
some pullin goodies
B & B Pulling Team
Hookin Ain't Easy!
Old 06-08-2009, 10:32 PM   #7
Ironhead107
I did. Nothing comes out of the dvs at all
Old 06-08-2009, 10:47 PM   #8
wrongway
Check your fuel shutoff solenoid. Make sure it is pulling all the way up when you are trying to start the engine. Bet that will fix it, and if you need a good price on a new one or the relay PM me. I have a place that treats us diesel guys good. Let me know how it turns out, Gary
wrongway is offline   Reply With Quote
Old 06-09-2009, 08:34 AM   #9
Ironhead107
I'll try it again. When I got it to run I had the whole solenoid off. Thanks guys, It's Cody Gary
Old 06-15-2009, 08:57 PM   #10
Ironhead107
That was it. I rigged a coat hanger up for now Thanks guys
