7.3l turbo diesel ?'s - ThePullingPlace.com
Go Back   ThePullingPlace.com > Ford Diesel & Truck Discussion > General Ford Truck and Excursion
General Ford Truck and Excursion Ford Truck and Excursion Discussion Non-Diesel Related Topics (lifts, tires, cosmetic modifications)
Old 01-11-2010, 09:57 PM   #1
kingoutdoormatt
Windshield Washer
Send a message via AIM to kingoutdoormatt Send a message via Yahoo to kingoutdoormatt
Default 7.3l turbo diesel ?'s
Can u put a 7.3 turbocharged diesel into a 1985 f250 and '85 f350 plus a 6sp tranny? What would i have to do?
Matt "Tuesday" King
My Garage
1992 Camaro RS 25 anniversity
1990 Buick Park Avenue
1985 Ford F-250 4x4 pulling truck
kingoutdoormatt is offline   Reply With Quote
Old 01-12-2010, 09:27 AM   #2
JIT
Never First
JIT's Avatar
You can but it wouldnt be easy. You would likely need a complete donor truck to make sure you have all the wiring and sensors. Youd be much better off doing a 12v Cummins swap as all the parts for that conversion are redily available and the cummins only needs 3 wires to run.
Team GDP
Fear the HoodStack
"Beating a Ford is like winning at the Special Olympics. Not really something worth bragging about!"
JIT is offline   Reply With Quote
Old 01-14-2010, 10:09 AM   #3
G D P
G D P's Avatar
yesyou can . is it idi or powerstroke?
Home Of The F.A.F. Product Line.
G D P is offline   Reply With Quote
Old 01-14-2010, 12:25 PM   #4
dieselbeef
dieselbeef's Avatar
my brother put a 2001 powerstroke out of a wrecked cab /chassis into an 85 dually that had a 460 in i think...gasser v8 anyways..fer real it was in a mag after the conv ..was a hell of a project...
he has done it if ya really wanna know the scoop lemme know. the ecm part was the worst..he had a custom one built
02 silver quad, iis silver 62,iis hrvp,100hp inj, 6'' cat stack, drag comp, smarty, bd intake, 35's on beadlocks, a werkin truck...
dieselbeef is offline   Reply With Quote
Old 08-16-2012, 08:52 AM   #5
Paul H
Windshield Washer
Paul H's Avatar
Yea the fuel system. wire harness ECM, IDM, and everything would have to swap over including the dash cluster. You would be putting everything from an OBDII truck into one that was before OBDII
Paul H
Thornville,Ohio
2004 Ford F350 6.0L Dualie 230,000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty
1996 Ford F350 7.3L Dualie 340,000 milesTony Wildman custom burn,5 inch stacks, Diesel Hot Rod
1995 Ford F250 7.3l 4X4 5spd sled puller
FOKISD CLUB MEMBER
Paul H is offline   Reply With Quote
Old 12-23-2020, 03:37 PM   #6
Ceasar Salad
Interesting thread
Ceasar Salad is offline   Reply With Quote
