ZF 5spd - ThePullingPlace.com
Go Back   ThePullingPlace.com > Ford Diesel & Truck Discussion > General Ford Truck and Excursion
General Ford Truck and Excursion Ford Truck and Excursion Discussion Non-Diesel Related Topics (lifts, tires, cosmetic modifications)
Old 03-07-2010, 12:16 PM   #1
mrt
Default ZF 5spd
I have a 1997 F350 with a 5 spd manual. has any one done any serious pulling with this transmission? Im want to build a 500 hp engine but im not sure if my transmission will hold up.
mrt is offline   Reply With Quote
Old 05-23-2010, 01:46 PM   #2
2wd_sled_puller
<<< MY day job
2wd_sled_puller's Avatar
it wont handle the abuse that a nv 4500 or 5600 tranny will but as long as u arnt jerky with it and dont jam it in gear u should be fine
97 f350 7.3
Valair clucth Air dog, soon to be sct tuned
97 chevy 2500
5 tons running gear, 54 inch tires, and a slighty tuned motor
2wd_sled_puller is offline   Reply With Quote
Old 07-25-2010, 12:11 PM   #3
Tim @ P.I.S.
Windshield Washer
They are tuff.
You can upgrade the input shaft to SD size, but the clutch is where you really need to spend the $$$.
Tim @ P.I.S. is offline   Reply With Quote
Old 08-16-2012, 08:54 AM   #4
Paul H
Windshield Washer
Paul H's Avatar
don't forget a single mass flywheel with the clutch
Paul H
Thornville,Ohio
2004 Ford F350 6.0L Dualie 230,000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty
1996 Ford F350 7.3L Dualie 340,000 milesTony Wildman custom burn,5 inch stacks, Diesel Hot Rod
1995 Ford F250 7.3l 4X4 5spd sled puller
FOKISD CLUB MEMBER
Paul H is offline   Reply With Quote
Old 12-23-2020, 03:37 PM   #5
Ceasar Salad
Shame it's old. I know the solution
Ceasar Salad is offline   Reply With Quote
