Bad Injector? - ThePullingPlace.com
Go Back   ThePullingPlace.com > Ford Diesel & Truck Discussion > 2003-2007 6.0L Power Stroke
2003-2007 6.0L Power Stroke General Discussion about the 6.0L Power Stroke Diesel.
Old 04-08-2009, 10:44 PM   #1
BullfrogJohnson
Moderator
BullfrogJohnson's Avatar
Default Bad Injector?
My buddies Dad has a 05 and it has a hard starting problem and once it cranks up it smoke bad. Not coolant smoke but fuel smoke. We have replaced the EGR and have had all the updates and reflashes done but nothing has fixed it. The truck initially threw a egr code but now is throwing injector codes very intermittently.
I have a feeling it has a injector but I have no idea of how to find out which one. I am not a 6.0 guy so please dont make fun for asking a silly question.
Thanks
Travis
Some Air, Some Fuel and Some Salad Tuning
B&B Pulling Team
BullfrogJohnson is offline   Reply With Quote
Old 04-08-2009, 10:55 PM   #2
wrongway
Any good scanner can tell you which injector it is. Kinda sounds like a FICM problem. I just done one the other day that had a very long crank time and the FICM was at fault. Pull the codes and let me know what they are and I'll see if I can help. Gary
wrongway is offline   Reply With Quote
Old 04-08-2009, 11:10 PM   #3
BullfrogJohnson
Moderator
Thanks Gary, I will get my buddy to pull the codes and get back to you
B&B Pulling Team
Old 04-09-2009, 10:55 AM   #4
WHITEPOWERstrok
WHITEPOWERstrok's Avatar
ive gotta set of stock injectors (4 have less than 100 miles, other 4 have less than 500 miles). $900 takes all for those
or ive gotta set of 190cc injectors that have less than 100 miles, practically brand new.
lemme know if he's interested in either of those...
2003 Ford F350 FX4 6.0L - 2007 Front Clip
16" Custom Lift/Dual Reservoir shocks/Traction Bars
42x15R20 Swamper SX2's/20x12 black XD Rockstars
Road Armor Stealth front-rear Bumpers/AMP Powersteps
Recon Smoked LED everything/Smoked LED 1 pc Headlights
ARP headstuds/EGR Delete/SCT Xcal3 Custom Tuned/RCD's 190's/maybe some other stuff
WHITEPOWERstrok is offline   Reply With Quote
Old 04-09-2009, 12:32 PM   #5
6.0superduty
6.0superduty's Avatar
like Gary said, run an injector buzz test when the motors cold.
07 LBZ
waiting to be modded
CODE RED (Sold)
04 6.0 CC SRW
some pullin goodies
2009 FATC Street Diesel Champion
Troyers Diesel Performance
Specializing In Superdutys
B & B Pulling Team
Hookin Ain't Easy!
6.0superduty is offline   Reply With Quote
Old 08-10-2012, 09:54 AM   #6
Paul H
Windshield Washer
Paul H's Avatar
I have seen stiction problems, wire harness problems, the FICM gives you a good ammount of info when you scan it with auto ingenuity. should show what injector circit is either high (open) or low (shorted). Also check the FICM itself for correct voltages key on before start, during cranking , and running a weak FICM can cause all sorts of things like studder or miss fires.
Paul H
Thornville,Ohio
2004 Ford F350 6.0L Dualie 230,000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty
1996 Ford F350 7.3L Dualie 340,000 milesTony Wildman custom burn,5 inch stacks, Diesel Hot Rod
1995 Ford F250 7.3l 4X4 5spd sled puller
FOKISD CLUB MEMBER
Paul H is offline   Reply With Quote
