Thread Tools | Display Modes |
02-13-2009, 12:28 PM | #11 |
as long as you do it correctly, and dont get too much heat, youll be fine. What I mean is, weld a little, break, weld some more....
07 LBZ waiting to be modded To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. CODE RED (Sold) 04 6.0 CC SRW some pullin goodies To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 2009 FATC Street Diesel Champion Troyers Diesel Performance Specializing In Superdutys B & B Pulling Team Hookin Ain't Easy! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Sponsored Links | |||
02-13-2009, 12:43 PM | #12 |
What about it? Spring perches, flanges, shock mounts, tubes, etc. have all been welded to axles.
We're all dealt unfavorable hands in life, it's all in how we play them out. "Folding" or "All In" is the difference between giving up or grabbing "Life by the Horns"! 05' Dodge 3500 Q-Cab 4x4 SLT SRW 48RE |
02-13-2009, 02:37 PM | #13 |
ive welded lots of brackets to axle housings and have never seen any problems. just glue'r to'er
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Home Of The F.A.F. Product Line. |
02-13-2009, 03:25 PM | #14 |
Love the glue! Glue it all
02-13-2009, 04:45 PM | #15 |
Never First
I glued a gnats azz to an Ants face one time. It provided me with hours of entertainment. I called it Azzface!
Team GDP Fear the HoodStack "Beating a Ford is like winning at the Special Olympics. Not really something worth bragging about!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
02-13-2009, 06:08 PM | #16 |
02-13-2009, 06:23 PM | #17 |
That is what I have on my pulling truck.
-Wayne To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 2008 44' Eliminator Powered By - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Shined By - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
02-13-2009, 10:41 PM | #18 |
i welded a little, moved to another. welded a little, moved to another. went around in a circle until i was done. they have take a good beating so far.
getting up this required a lot of articulation as i went at an angle and no problem. not to mention the repeated flogging it all night(burnouts, donuts, hard launches, off roading). im happy so far. Garrett
2003 F-250 6.0 XLT 4WD auto CCSB- SCT with DJ's Looney tune, airdog FP-150 with a custom fuel system by me, 4" straight pipe to 6" black cat stack, lots of other little things and train horns. 1994 2500 12v 5spd 4wd RCLB- a header and some timing with some springs, needs more air, fuel, and a clutch 382hp/1000tq Elite Diesels To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
02-16-2009, 12:22 PM | #19 | |
But have you ever wondered what it does to the fit and pre-load on the axles. The axle is straight, or better be. If the tube is not 100% straight how do you think the fit between the axle and spider gear(S) is. I just know from past experience. Whenever I have had any spring mounts moved on a rear housing it was done with a fixture to make sure a true alignment through the housing was maintained. |
Sponsored Links | |
Thread Tools | |
Display Modes | |
