Performance characteristics of atmosphere sintering furnace - ThePullingPlace.com
ThePullingPlace.com
Go Back   ThePullingPlace.com > Ford Diesel & Truck Discussion > 2003-2007 6.0L Power Stroke
Forgot Password?
2003-2007 6.0L Power Stroke General Discussion about the 6.0L Power Stroke Diesel.
ThePullingPlace.com is the premier Truck/Tractor Sled Pulling Forum on the internet. Registered Users do not see the above ads.
Reply
Thread Tools Display Modes
Old 01-27-2021, 03:42 AM   #1
wyb2020
Rookie
Default Performance characteristics of atmosphere sintering furnace
1. The furnace body is an integrated structure with double-layer shell, which can realize air circulation and heat insulation; the surface of high-quality carbon steel is used for rust removal and electrostatic spraying, which meets the international laboratory standards.
2. The furnace is made of imported light and high-purity alumina, with high hardness and no powder dropping, high-temperature sintering and no volatiles, which is safe and environmentally friendly and in line with international industry standards.
3. The heating element is made of high-quality molybdenum resistance wire, which is designed to be heated on both sides with good temperature uniformity.
4. When the instrument program is set, as long as the operation button is pressed, the next heating and cooling work will be completed automatically without manual waiting.
5. This machine will send out alarm signal for over temperature in work, and automatically complete protection action.
6. The control panel is equipped with power indicator and heating indicator, which can inspect the working status of the equipment at any time.
7. Brand circuit breaker is installed on the side panel of the equipment. In case of short circuit or leakage, the air switch will be automatically protected, which will not cause hidden danger to human body or damage to the equipment.
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
wyb2020 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
