Testers needed - ThePullingPlace.com
Go Back   ThePullingPlace.com > Vendors > Rick Lance
Rick Lance Custom Headers & up pipes for Duramax Trucks
Old 12-13-2008, 05:59 PM   #1
RickDLance
Default Testers needed
I'm needing a few testers for some minor changes I want to make in my header setup. If you're interested in getting a set of headers for a discount and don't mind getting your hands dirty then please PM me. Thanks!
RickDLance is offline   Reply With Quote
Old 12-14-2008, 05:19 PM   #2
ChevyDieselLLY
Rick i will be building an engine March - April time frame. it will have stage 2 heads from SoCal, full bottom end, dual fuelers, turbo is undecided but at the moment i am thinking about a GT42 or GT42Mag. Dustin and Winston at Diesel Addiction will be doing the build and will have a little more info on the specs of the engine. i know Dustin just installed a set of yours. let me know if what i will be doing is something you may want to try out. but like i said it wont be for a few months.
ChevyDieselLLY is offline   Reply With Quote
Old 12-15-2008, 10:32 AM   #3
RickDLance
Keep me in the loop.
Old 12-15-2008, 08:36 PM   #4
JIT
Never First
JIT's Avatar
Rick are you building them for 24v cummins? If so I am all ears... need a T3 flange.
josh
Team GDP
Fear the HoodStack
"Beating a Ford is like winning at the Special Olympics. Not really something worth bragging about!"
JIT is offline   Reply With Quote
Old 12-16-2008, 10:03 PM   #5
RickDLance
Sorry, but just the Dmax for now.
Old 12-16-2008, 10:58 PM   #6
04BlackSmoker
What kind of set up do you perfer to put these on???
04BlackSmoker is offline   Reply With Quote
Old 12-17-2008, 09:07 AM   #7
RickDLance
To qualify you MUST drive your truck daily, make at least 40 pounds of boost
at WOT, make at least 1600 degrees egt on a regular basis, and make approximately
600 HP or more. You must also be willing to install and remove the headers
multiple times if needed and ship them back to me as needed.
Old 03-08-2009, 06:34 PM   #8
DocDyno
Default Herders
Rick,
Just saw this. We have a DMax LLY in one of our engine dyno test cells at the present time. If you would like some real data, temps, pressures, A-B comparos, etc. Let me know. We could run the data for you while we are working on some calibration and component development with this engine.
DocDyno is offline   Reply With Quote
Old 03-10-2009, 07:24 PM   #9
RickDLance
Where are you located? Is it a stock motor?
Old 03-10-2009, 07:46 PM   #10
DocDyno
We are in northern Indiana. Yes it is a stock motor.
Powered by vBulletin® Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
